wilwood dynalite
wilwood dynalite
Postby ke_25 » Mon Aug 18, 2008 2:59 pm
hey was wondering if anyone knows if ferodo lucas or bendix do a db equivalent to fit wilwood dynalite calipers? went through the ferodo book n found nothing but yeah help appreciated
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby IH8TEC » Mon Aug 18, 2008 6:35 pm
have you looked at all the wilwood compounds? and they are cheap.
Postby ke_25 » Mon Aug 18, 2008 7:04 pm
where bouts from? i was only looking at those brands as i can get cheap cheap. rang 0800racebrakes and they do a ferodo race psd but its 200+ cost.
summit is also cheap but stil 60us shipping
ke_25
Postby IH8TEC » Mon Aug 18, 2008 11:04 pm
go to cardwells racing supplies in Albany AK, they are the nz distributer for wilwood. pretty sure they were either 160 or 180 for whichever compound you choose.
Postby NZ_AE86 » Tue Aug 19, 2008 1:03 pm
It will also amaze you at how long they last! spend good money and get good stuff!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby IH8TEC » Tue Aug 19, 2008 5:20 pm
just dont get the "smart" pads from wilwood. brake dust is a C#NT
Postby Dunny » Tue Aug 19, 2008 6:46 pm
Les Hunter does wilwood and i could almost guarantee he will be cheaper than Cardwell's, depending on the compound you want, your looking between $120-$160+gst for a set of fronts.
And they do last ages
Dunny
Postby Bazda » Tue Aug 19, 2008 9:50 pm
Cardwells is the same price as Les Hunter.
I got quotes from both in a smart pad and both were the same price. Back then it was something like $130 incl gst.
Basically you have 4 types of pads you can get.
Polymatrix A , B and C for circuit sprint racing
Polymatrix H, J for long distance type racing
Polymatrix E and Q for street use (lowest dust out of all the pads)
Smart pad bp10 and 20 street/track days
They all make lots of dust except for the E and Q, but def cant be used on the race track as their temps arent rated high enough and will basically melt down.
Polymatrix is usually more expensive than a smart pad.
So depending on what yoru going to use the car for will depend on what pad you need.
Im actually am going to run 2 pads, one for road and one for track. The race pads wear VERY quickly when used on the road as they are not in their operating temperature.
