ST185 3SGTE - Code 14
Postby Boosted_162 » Mon Aug 18, 2008 7:32 pm
Im trying to get my RC going. When its been left a while it will start, and idle fine for a while then will cut out. The wont start again. Only code coming up is 14 which is:
14 Ignition Signal
Diagnosis
* No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
* Igniter and ignition coil circuit
* ECU
Now i have replaced the igniter and coil today, and no luck. What should i look for next? Gunna try track down a RC ecu and try it out (Still got yours Cliff?)
Postby RS13 » Mon Aug 18, 2008 8:23 pm
Sounds like your fuel pump is knackered, or you've got a fuel blockage somewhere.
RS13
Postby Boosted_162 » Mon Aug 18, 2008 8:25 pm
RS13 wrote:Sounds like your fuel pump is knackered, or you've got a fuel blockage somewhere.
I can smell fuel after its been cranking. Judging by the code id assume theres no spark? Oh and also making the fuel pump run (fp and b+) doesnt change anything.
Postby RS13 » Mon Aug 18, 2008 8:33 pm
Seems odd that the ignitor would fail in that way, normally an ignitor works or it doesn't, (coming from experience with Nissans) as well as the stable idle before it dies.. hmm.
At least try starting it, if it doesn't start, I'd pull the fuel line off and check for flow. Does it die any faster if you give it throttle?
RS13
Postby Boosted_162 » Mon Aug 18, 2008 8:34 pm
RS13 wrote:Seems odd that the ignitor would fail in that way, normally an ignitor works or it doesn't, (coming from experience with Nissans) as well as the stable idle before it dies.. hmm.
When it does actually start (only when its been sitting a while) it will run and drive perfectly. Then it will just cut out and wont start again. Turns over with heaps of power. Im gunna borrow Cliffs ECU sometime and see if that chages things.
Postby RS13 » Mon Aug 18, 2008 8:36 pm
Ah ok. Well its' sure a curly one! Good luck man, I hope it is a simple ECU fault. :)
RS13
Postby Boosted_162 » Mon Aug 18, 2008 8:39 pm
RS13 wrote:Ah ok. Well its' sure a curly one! Good luck man, I hope it is a simple ECU fault. :)
I dunno if i want it to be a ecu fault, RC parts are bloody hard to find! :lol:
Postby fivebob » Mon Aug 18, 2008 8:43 pm
How did you check the codes?
Did you turn the ignition on before bridging the check terminals, or after?
Postby Boosted_162 » Mon Aug 18, 2008 9:01 pm
fivebob wrote:How did you check the codes?
Bridge terminals, then turn ignition on. Cleared codes before to be certain.
Have taken ecu out, no signs of anything wrong. But noticed the Defi VSD has been wired into the ecu. Might try unplugging to see if its interfering with the signal.
Postby fivebob » Mon Aug 18, 2008 9:39 pm
That will be why you are getting a false code 14 then. The correct procedure is to turn the ignition on then bridge the terminals. Code 14 is transient and not stored in the ECU so it's there when you turn the ECU on, and is cleared soon after.
Postby Boosted_162 » Mon Aug 18, 2008 10:18 pm
Ok well i went out and tried again.
I put new battery in (so there will be no codes stored). I started it and ran it for a little while, then it started to splutter and die. Throttle couldnt save it. Left ign on "on" so all warning lights were on. Code 14 again.
Unplugged the VSD and it didnt change a thing :(
Just one thing i remembered. My original ignitor had a slightly different part number. Could that be it? Both other ignitors i had tried were GT4/3SGTE ones. Part numbers are 1 off.
Postby fivebob » Mon Aug 18, 2008 11:07 pm
What year is your GT4,
Part # should either be 89621-12010 for production dates before 9108 or 89621-12050 after that.
Postby Boosted_162 » Mon Aug 18, 2008 11:32 pm
Its a 1992. All my igniters are 89621-12050 but the one that came in the car has PHD1 written on it in big letters, and my other 2 have 201 on it. And the Denso numbers are different... 131300-2010 compared to 131300-2011.
Postby XS1V » Wed Aug 20, 2008 11:23 am
This is very weird, sounds like something heats up then breaks the circuit. This could be in the ECU etc etc as you have said. Can come have a look in the weekend if you like??
Brad
ST205 Group A Rallye #2363
XS1V
Postby Boosted_162 » Wed Aug 20, 2008 7:36 pm
XS1V wrote:This is very weird, sounds like something heats up then breaks the circuit. This could be in the ECU etc etc as you have said. Can come have a look in the weekend if you like??
Brad
Sure, im running out of ideas quick! Gunna try Cliff's ECU, but other than that i dont know!
Postby matt dunn » Wed Aug 20, 2008 8:22 pm
My guess for a toyota would be,
Not ECU,
Not igniter,
Coil or wiring.
The igniter recieves the IGT signal from the ECU and fires the coil,
and when it sees the high spike in the coil -ve you get when spark occours it triggers back on IGF to say it's fired.
No power to the coil, or faulty coil will give that code, as you dont get the spike.
Postby Boosted_162 » Wed Aug 20, 2008 8:49 pm
matt dunn wrote:My guess for a toyota would be,
Not ECU,
Not igniter,
Coil or wiring.
So you'd say to check/replace the coil, and check the plug and wiring for it?
Oh and does the coil earth through the bracket like the igniter does? (i think the igniter does?)
Postby matt dunn » Wed Aug 20, 2008 10:22 pm
Yes
The igniter earths the coil, so the main coil current goes through the igniter earth which is the case,
so check the igniter is bolted to earth and is tight.
Postby Boosted_162 » Thu Aug 21, 2008 9:51 pm
Its the ECU.
Cliff was just here, so we put his ECU in. Ran like a charm, got to operating temp and idled perfect.
Now the hard job of finding an RC ECU....
Postby Dell'Orto » Fri Aug 22, 2008 8:58 am
PM anth_555, I think he had one, could still have it. Also, you may be able to get it repaired, there is a company in Nelson (and there are probably others) who repair ECU's.
