by dzk » Sun Aug 31, 2008 10:45 am
Sorry to hijack this one but my brothers car has the same symptoms. Starts fine but cuts randomly and then takes awhile to start sometimes.
Car - 1991Mitsubishi Proton Saga 1500cc carb'd
Things checked/replaced recently
*oil filter and oil change, flushed radiator.
*air filter
*new thermostat
*Fuel filter and fuel lines cleaned out using thin wire to get gunk out.
*Taken to auto sparky who can't fault it and drove it for an hour but it didn't cut.
*Have checked the dizzy for moisture but appears dry.
The dizzy on this just has the four plugs that go to the sparkplugs. No fifth one going to a coil so would the coil be on the inside?
Any help or comments would be appreciated. Not too sure if you can get new dizzy for a car this old.
Thanks
Previous Rides
st185 143kw atw at 10.5psi
ae92 Corolla wagon
ae92 Corolla sedan
ae92 Levin
b16a Integra (Current)
