I'm still trying to sort my brake system out. I've installed new calipers after the last ones were leaking, bled the lines at each wheel but the pedal is still spongey, although it doesn't go right to the floor.
The car will stop, but just takes its time and the rear brakes are locking up too.
While the calipers were leaking the master cylinder resovoir was completely emptied of fluid - hence sucking air through.
Is it likely that the master cylinder itself will need bleeding, separately to the brake lines? I've read that this needs doing when installing a new cylinder to remove the air from it, so I'm guessing the same would apply for when the fluid has run out.
Also, is it a major issue if the proportionary/bias valve is fitted level or slightly above the master cylinder?
-Matt
