Makaveli wrote:Is there a special socket that u need to use? I think toyota recommends bi-hexagon 10mm socket???
TRD_ZERO wrote:Yeah it s a blacktop head I was using the right bit but i was going in at a slight angle withought taking the cam out. the teeth inside the head of the stud where the bit sits into is stripped clean not the thread of the stud to block. I dont have a welder i might try drill it out.
