Replacing speedo cable on AE92
Postby KwS » Tue Sep 23, 2008 6:01 pm
Hi. Yes, i have searched but didnt manage to find much on this subject.
How hard is it to change the speedo cable on an AE92? Does the dash have to come out, or can i just take the cluster out and feed the new cable through?
How much is a new cable also?
KwS
Postby gasman » Tue Sep 23, 2008 7:48 pm
the speedo cable can be broken into 2 pieces in the engine bay. do that then just pull the cluster out allong with the cable
"What can possibly go wrong?"
gasman
Postby KwS » Tue Sep 23, 2008 8:32 pm
gasman wrote:the speedo cable can be broken into 2 pieces in the engine bay. do that then just pull the cluster out allong with the cable
how can i tell which bit is snapped? can i turn it and see if the other end turns, or could it still turn if its stuffed or something? got a pics of the bit where it can be broken into the two pieces?
KwS
Postby crispy'86 » Tue Sep 23, 2008 9:14 pm
unscrew the speedo cable and get someone to spin it by hand while you watch the speedo. If it flicks then that half is working. Same with the gearbox end. remove that and spin it, see if both ends turn. Chances are the lower half is broken.
crispy'86
