Limit Steering Travel?
Postby 1e-pwr » Fri Sep 26, 2008 1:16 pm
Howdy
I have an EP70 Starlet running 195/50/15s and get inner guard rub on both sides, although one side worse than the other. I am just wondering whether there is any way to limit the throw of the steering so this is no longer an issue. The car already has problems with traction so dont want to go to a thinner tyre, and Id probably go to a 205 if I could come up with some clever way of limiting the steering travel. Could some kind of stoppers be added to the ends of the rack so that the pinion is limited at the ends? Any ideas of the legality of such an approach? The car needs to go for a cert hence need to fix wheel rub, dont want to fix with a solution that is also uncert worthy though...
1e-pwr
Postby molex » Fri Sep 26, 2008 3:05 pm
Hammer. Seriously though, how bad is the rub? that last little tiny bit of the steering lock? or a decent angle of the wheel?
What offset are your wheels? I run 205/50/15's on 15x7s in the front of my Glanza, they're +35's. Any higher offset and I would have the same issue.
molex
Postby 1e-pwr » Fri Sep 26, 2008 3:48 pm
Have already massaged the wells with Mr Ball Peen. The rub isnt super terrible, but enough to fail WOF... Wheels are factory BZR wheels, not sure of offset, wouldnt wanna go any more backspace though cause I get rub under compression on the outside edge as well...
1e-pwr
Postby rollaholic » Fri Sep 26, 2008 5:53 pm
flares & wheelspacers!
Postby molex » Fri Sep 26, 2008 6:15 pm
Factory wheels are something like +45 or more if I recall correctly. I'll ask mr Google
Roll guards + spacers/lower offset wheels would be the way to go, a few mm could make all the difference...
molex
Postby Mr Revhead » Fri Sep 26, 2008 6:41 pm
you could maybe make up lock stops
a lot of cars have them.
mount on the hub, usually a bolt with a plastic cover that contacts a plate on the lower arm
have a look at a surf to get the idea
Postby 1e-pwr » Fri Sep 26, 2008 8:25 pm
Alas its tricky with the Ep70 arches, they are designed for teency 155s! The new wheels I have for my nana mobile are facto corolla 15s (4x100), so dunno if theyll improve things/make it worse. What I might try is messing some more with the arm adjustments, still a little toed in and with adjustment might be JUST enough give in the barely rub side to make up the difference. I was thinking of somehow 'inactivating' the outermost teeth of the rack (with machined inserts of steel or nylon), thatd limit throw, but have no idea if this is feasible (and more importantly legal) having never dissected the innermost workings of a steering box...
1e-pwr
Postby QikStarlie » Fri Sep 26, 2008 8:46 pm
chop some off the end of the rack. done.
QikStarlie
Postby Malcolm » Sat Sep 27, 2008 10:36 pm
should easily be able to make up some cylindrical spacers that go over the ends of the rack, which are retained by the rack ends, and which contact the steering rack housing at what you desire to be full lock.
Postby 1e-pwr » Sat Sep 27, 2008 10:49 pm
Thanks guys, exactly the kinda solutions I was after. Will pull it to bits and have a look what can be done, if can remove some length from the rack and still retain enough internal thread then will go that way, otherwise will look at the bush route. Also need to talk to certifier about the legality of either method... Cheers guys, no power steering 205s here I come :D
fast, reliable, subaru: pick two
1e-pwr
Postby Malcolm » Sun Sep 28, 2008 12:14 am
shortening the rack will affect your bump steer, just so you know (can't say whether it'll be in a good way or bad way though). If it's only a few mm it probably wont be noticable though
Postby DexGT » Sun Sep 28, 2008 12:44 am
I made and fitted some 7mm spacer rings from acetal that are on the rack inside the inner rod ends . They have been fitted now for over a year no problems and more importantly for me no blown C.V's since fitting .
As they are inside the inner CV boots I can't see how a WOF guy will even know they are there :wink:
DexGT
Postby 1e-pwr » Sun Sep 28, 2008 10:23 am
Sweet, did you measure the amount of travel that needed to be removed lock to lock to derive the 7mm measurement, or guestimate? Any pics? What width tyres are you running? EP82 right?
1e-pwr
Postby DexGT » Sun Sep 28, 2008 7:33 pm
From memory I made a few diferent length sets up and told my wheel allinement guy to use the ones that made the tyres miss the rubbing point by 5mm or so . It's been a while but I'm pretty sure he used the 7mm ones , that was with 205 15" semi slicks , trial and error basically :) .
Yes it is a EP82 GT.
DexGT
Postby drift-monkey » Sun Sep 28, 2008 9:54 pm
just do the opposite to making more lock, i machined a few mil of the rack ends sotd slide insede the steering rack so if u just machined the rack ends opposite
like this...
drift-monkey
