I havent had any luck finding 1 to suit the 20 valve. But have found plenty to suit the 16 valve.
Are the interchangable?
Does any one know were i can get one to suit 20 V?
thanks
ke25sr wrote:I havent had any luck finding 1 to suit the 20 valve. But have found plenty to suit the 16 valve.
thanks
1I1 wrote:I got told last week by on_psi that you can simply add a washer to shim it?
Mr Revhead wrote:yeah, sump mods should be higher on the list than more volume
stock pumps are fine to around 9500 rpm or so
blacktop oil pump has mounts for the tensioner on it
what have you done to the engin to need the better pump?
Users browsing this forum: Bing [Bot] and 21 guests
