previous people wrote:tiny little Thrust washers ... no oil pressure ... cold starting ... stronger the pressure plate the worse
xsspeed wrote:So for these cars that need the clutch in to start.
If it is a bad thing, why do they have it? (is it a safety thing incase the gbox is in gear?)
CAMB01 wrote:4G63 turbo engines are VERY VERY common for thrust failure and crank walk.
Mainly due to the later model evos having pull clutches, and starting with foot on clutch.
Seen four evo 4 engines at work with the same problem, bin the crank and the block. Once it chews through the bearings it eats into the block
