Blacktop hydraulic tensioner not tensioning
Postby ATAl » Sat Oct 04, 2008 12:09 pm
I've just installed the cambelt on my black top 4age but the hydraulic tensioner isn't putting very much pressure on the belt at all, the cam belt is jumping off the cam teeth.
The tensioner seems to be as far out as it'll go (about 1cm from the compressed position).
Is there any way to 'pump up' the tensioner?
ATAl
Postby Bling » Sat Oct 04, 2008 12:15 pm
is it new or are you reusing an old one?
Postby Mr Revhead » Sat Oct 04, 2008 3:13 pm
its stuffed, get a new one
you should ALWAYS replace the tensioner when u do the belt on a black top
they will not last 200,000 kms
Postby matt dunn » Sun Oct 05, 2008 10:10 pm
I found I only got one use of of them.
Put a new one on, pull the pin and it expands,
and if you needed to pull it of again,
had to get another.
I converted the hydro tensioner to mechanical.
Postby Bling » Sun Oct 05, 2008 10:56 pm
Yeah only designed to work once. I guess that would be quite expensive on a race car that gets fiddled with.
Did you just put a silvertop one on Matt?
Postby ATAl » Mon Oct 06, 2008 7:44 am
It is a new one :D
But it did sit around for at least a year.
ATAl
Postby ATAl » Mon Oct 06, 2008 7:45 am
Matt: What was involved in converting to the mechanical tensioner?
ATAl
Postby Bling » Mon Oct 06, 2008 4:38 pm
pulled the pin obviously? :lol:
Postby matt dunn » Mon Oct 06, 2008 10:30 pm
ATAl wrote:Matt: What was involved in converting to the mechanical tensioner?
rip all the guts out and make a core for it that takes a threaded rod through the centre,
dad did mine, was few hours work,
