Boosted_162 wrote:Damn.
This isnt the first time you've had problems with flywheel bolts is it?
l1ttle_d3vil wrote:your car is too fast, turn your boost down.
or possibly an "incompatible engine"![]()
but seriously, thats scary
BZG|Bling wrote:i'll take a stab at too many rpm and shes given up
Bazda wrote:I didnt have my standard flywheel on for long enough to find this out. All my car did was clutch slip so just went to a twin plate with custom billet flywheel.
The flywheel is acutally cheap to make if you supply the std ring gear.
Think my flywheel was under $300.
