2jayzgte wrote:I think there is a few more tricks to the Croydons Supra than just the work under the hood.I think you'll find that the suspension will be fairly trick.Also there has been alot of thought and huge $$$$ put into this car these are some of the reasons why its a drive to the track 9 second car.
Dell'Orto wrote:2jayzgte wrote:I think there is a few more tricks to the Croydons Supra than just the work under the hood.I think you'll find that the suspension will be fairly trick.Also there has been alot of thought and huge $$$$ put into this car these are some of the reasons why its a drive to the track 9 second car.
Wasnt anything particularly flash from memory, just a set of specific valved drag shocks. The 600+kw would have helped no end however
Would have been cheap racing for someone, they only wanted $45k for it.
BlakeNZ wrote:the extra timing and boost you can run with 110 octane(the haltech can have switchable maps) will allow power increases of around 10 percent.(as evidenced by my car, with switchable Maps) . your 60 foot time will be the biggest factor as to drag results. so minimise lag. of course, activating the haltech's antilag will give you 15psi boost on the startline, so you could go very fast(low to mid 11s) if you chose.
postfach wrote:Antilag does nothing for a drag launch, it's only activated when you lift your foot off the throttle, to keep the turbo spooled during a gear change.
You need launch control to get boost on the start line, which is similar to antilag in principal but works with the throttle wide open.
cat007 wrote:postfach wrote:Antilag does nothing for a drag launch, it's only activated when you lift your foot off the throttle, to keep the turbo spooled during a gear change.
Well sort of.....
Antilag doesn't just mean rally style - that's just what people relate to rally.
I have drag mode antilag in my car with the Stinger but only set up so it's off above 70% throttle and above 4,000rpm
With more practice I'd set it up so it ignores the TPS, turns on above 4,000rpm and ONLY turns off when above 5psi. That way you can burry your foot, hold it below 5psi - when you dump the clutch and the engine loads up, you'll instantly get more than 5psi so it turns off.....
