RS13 wrote: In terms of suspension, he thinks that by softening the front right, thereby putting more load on the wheel, (together with an increase in camber) would get it to bite. I would have thought that more stiffness would be better?
Thoughts?
RS13 wrote: Ruapuna, which is largely a right-hander track.
Mr Revhead wrote:be aware that adjusting the bar unevenly each side stiffens it unevenly....
Asymmetric is the opposite to symmetric and implies the use of differing holes on each side of the swaybar. For example, this might involve setting the left hand side to the hardest setting of 3 while the right hand side might be set to the middle setting. Contrary to what some people think it does not equally split the rate difference between symmetrically using setting 3 and setting 2. That is, the resultant rate is also asymmetric with more roll stiffness on one side compared to the other.
d1 mule wrote:RS13 wrote: Ruapuna, which is largely a right-hander track.
that may be your problem there man, ruapuna is a LEFT handed track
note: racing direction is Anti clockwise
http://www.canterburycarclub.co.nz/Track/Maps.php
GP track 7 left. 3 right
Club track 6 left. 2 right
B track 5 left. 2 right
A track 3 left (5 left. 1 right with dipper)
KinLoud wrote:I'm not suggesting that driving skill is causing the problem but it can be a factor.
