Crank Pulley Bolt Removal Method Options
Postby Makaveli » Tue Oct 28, 2008 10:18 am
Option 1: Use the Toyota SST tool to prevent the crank pulley turning while you undo the pulley bolt (two SST options)
Option 2: Remove the starter motor and lock the flywheel gears using a custom made plate with a single tooth to prevent the flywheel turning.
Option 3: Similar to option 2 but using screwdriver/crowbar or similar to lock the flywheel gears (RANGI).
Option 4: Put a power bar on the pulley bolt against the floor and flick the starter switch, hoping it will undo the bolt (RANGI).
Option 5: Using Impact Gun undo the bolt.
Just wondering what would the average mechanic do to undo the bolt? I doubt they will have the Toyota SST nor the custom plate to lock the flywheel for every different car they do. Is there a good way of doing it????
:roll:
Makaveli
Postby Bazda » Tue Oct 28, 2008 10:32 am
Rattle gun 99.9% of the time.
If you dont have one, just put it in gear and get someone to hold the brakes on for you then undo with a big bar.
Postby MrOizo » Tue Oct 28, 2008 10:36 am
I've used option 3 and 4 - no worries!
Another thing i did was with the engine out and the box off, put one bell housing bolt back in and link either chain or rope to the flywheel in the right direction and that will work against you when you un-do the bolt.
MrOizo
Toyspeed Legend
Postby Makaveli » Tue Oct 28, 2008 10:41 am
Thanks :D
Makaveli
Postby tsoob » Wed Oct 29, 2008 9:20 am
Bazda wrote:Rattle gun 99.9% of the time.
YEP :P
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby evil_si » Wed Oct 29, 2008 11:25 am
my common methods of choice are
impact gun,
jam the flywheel with prybar
if gearbox is off bolt a chain to the flywheel and to a 'fixed' bolt hole,
wedge powerbar in and crank engine, 1 quick turn of the key usually does it.
evil_si
Postby Akane » Wed Oct 29, 2008 11:35 am
Used option 4 many times on the MR2, works without fail.
Now that I have a impact wrench, I'd just do it properly.
Postby cat007 » Wed Oct 29, 2008 3:49 pm
oh man - a rattle gun on the crank pulley bolt? YUCK!
I've never, and will never, put my bearings and thrust washers through that sort of punishment
Postby Makaveli » Wed Oct 29, 2008 5:10 pm
BTW wouldn't a rattle gun make the engine turn anti-clockwise? Which is a big no-no as I know. I think locking the flywheel is a must then using a big power bar to undo it.
Makaveli
Postby Lloyd » Wed Oct 29, 2008 5:26 pm
You have all the right options, just in the wrong order. Try number 5 first, if it doesn't work then try 4, then 3, 2 , 1.
Postby phoenix » Wed Oct 29, 2008 9:48 pm
Makaveli wrote:BTW wouldn't a rattle gun make the engine turn anti-clockwise? Which is a big no-no as I know.
If the rattle gun is up to the job the crank will barely move. This is one of their advantages, instantaneous torque.
What supposed to happen if you turn it backwards anyway? Will it turn into a honda?
I've used method 4 a few times on JZs, they usually seem to be stuck tight. If that doesn't work I generally drop the plugs out to ease the load - assuming your battery is up to it in the first place.
phoenix
Postby peas » Thu Oct 30, 2008 9:49 pm
Never had the starter kickover method fail on me yet... Have had a rattle gun on two of my cars now that failed to budge after a solid 2-3 minutes.
'97 Caldina GT (ST215G)
peas
Postby AE82 FXGT » Thu Oct 30, 2008 9:59 pm
^ agreed, starter motor works a treat, just stay away from the engine bay when flicking the key.
A good 6pt socket and power bar is awesome.
AE82 FXGT
