Brake problem... odd noise
Postby BlakJak » Fri Oct 31, 2008 7:49 pm
I had a wheel bearing done by a local garage recently.
Ever since I got it back from them, i've been hearing an odd rubbing type noise under braking - only hear it in the last coupla wheel revolutions before coming to a stop, and only if it's dry and there's no background noise...
It's been this way for a coupla weeks so I got frustrated with it tonight and jacked up the car, took off subject wheel (rear left) and with some help from the mrs, attempted to simulate. Only happened under braking so I had the mrs gently push the brake pedal while I spun the wheel and listened for oddities.
This is what I found:
Click for biggest version: http://gallery.blakjak.net/v/Toyspeed/B ... ewsIndex=2
The 3 shots are available in different sizes at http://gallery.blakjak.net/v/Toyspeed/B ... ghtId=9759
My guess is that blemish on the brake disc is making the odd noise when I brake... it's really annoying, I was worried I was damaging something to start with.
The mechanic tells me 'it takes a while for things to bed back in'. That's fine but I'm not sure how the above pictures mesh with what he told me.
What does TS think?
What does TS think?
BlakJak
Postby Lloyd » Fri Oct 31, 2008 8:01 pm
If the pads look sweet and there are markings in a particular spot on the rotor then get them skimmed or chuck new rotors on
And for the record, I've seen some pretty horrible rotors that dont make a single noise and work perfectly. Take the pads and find a bit of concrete to roughen the surface up on and see if the noise is still there afterwards.
Postby flygt4 » Fri Oct 31, 2008 8:14 pm
have had a similar noise from a bent backing plate too. i rebuilt the whole caliper and changed pads and rotors before i figured it out.
flygt4
Postby BlakJak » Fri Oct 31, 2008 8:21 pm
Noticed I fudged the second image. Fixed.
How do I know if I have a bent backing plate?
Is it possible the mechanic screwed something up?
BlakJak
Postby Dell'Orto » Fri Oct 31, 2008 8:30 pm
What are the pads like? That kinda marking is similar to low pads markign the rotor.
Postby BlakJak » Fri Oct 31, 2008 8:37 pm
didnt look at them too hard - but there's no squeak yet, and I passed a WOF at the same time as I got the wheel bearing done.
BlakJak
