OK so clutch is all done - albeit needs re-bleeding - feel's very very soft and the gears are notchy.
I had an issue on Sunday with putting the drivers side axel in. I stupidly pulled it out of the CV when taking the whole thing apart. I couldn't get the axel circlip in. It kept bending as I would push the axel into the hub. I'm guessing its the original clip, so it'd probably lost a bit of spring. I was told by my mates mum to just leave it and she will sort it on Monday for us to come and collect Monday night
Sure enough after a few issues on Monday (like me putting subframe up without the exhaust and the exhaust being too bit to fit) she finished the car.
Awesome - After work on Monday we go to collect
Clutch feels soft and gears a notchy - that's fine - I'll re-bleed it later, as long as it goes
Anyway - last night - as my partner pulls out of her work drive to come pick me up. Full lock left turn to get out of the drive. She hears a funny noise but thinks nothing of it. Then at a set of lights up-hill when she tries to take off, there's a horrible grinding noise and clunking. She finds someone to help push her to a side road.
I get a call from her saying "my cars fu(ked", so I quickly leave work and walk/run to her car. Sure enough - drivers side axel WASN'T pushed in properly - and has popped out of the hub!!!
I called my mates mum up - and luckily her daughter comes to the shore every Wed to see her partner - so she'll come help us.
Cant get the axel in all the way - held the axel in place with 2 big zip ties and slowly drove home (from center of town to Torbay!!). Most fuel efficiant drive I've ever done LOL
She follows us home making sure we get there safely and blocking off the road where need be so we can make very wide sweeping turns as hard turns would probably cause it to pop out again.
So the 5UPRAH is now the "sit in traffic and drive to work" car. Which really sucks - as it costs $20 a day to run into town and back - compared to less than $10 a day for the GTT. Will be sorting a new "clip" today - and should be able to repair it this Saturday.
joy joy joy
