Uniden 2stage Shock Sensors
Postby l1ttle_d3vil » Sun Nov 02, 2008 11:48 am
How do the Uniden 2 Stage Shock Sensors work?
There are two dials on the sensor but I've got no manual to say which dial does what.
At the moment, the alarm is going off every time a car drives past :twisted:
-Matt
Postby johndoe1025 » Sun Nov 02, 2008 11:57 am
its the sensitivity of each stage. stage one is the beep beep stage and stage two is the siren goin off. i think? just wind them both back a little bit lock the car and smak on ur a pillar to check the sensitivity
johndoe1025
Postby l1ttle_d3vil » Sun Nov 02, 2008 12:11 pm
sweet that sounds about right, will pull everything out and wind it back.
Postby zolar » Mon Nov 03, 2008 6:31 pm
Most uniden use Red and Orange pots for adjustment.
The Orange one is for the chirp/warning sensitivity.
The Red one is the full alarm setoff sensitivity.
Make sure the Orange one is set to less sensitivity then the Red one, or you'll find when the sensor gets set off, it'll go straight to a full alarm without chirping first.
Pretty sure they're clockwise for more sensitive, anti-clockwise for less sensitive.
Robert
zolar
Postby RunningRich » Mon Nov 03, 2008 7:23 pm
Make sure it is solid mounted. I strap it solidly to the steering column so that a light kick to the front wheel makes it chirp, a hard thump sets it off.
Richard
http://gtfour.supras.org.nz
RunningRich
