RunningRich wrote:Interesting as the backwards vents on ST205's are not "baffled".
How do you "baffle" a vent without blocking it??
Above the turbo a ST205 has a large grill. I get huge rushes of steam out of it when going through a puddle.
d1 mule wrote:whenever there is anal scrutineers just puit some tape oner it then take it off just before racing, many a drift competetior do it
Adoom wrote:Can someone explain to me this baffling? and how can I baffle it without defeating the purpose of the vent?
B1NZ wrote:d1 mule wrote:whenever there is anal scrutineers just puit some tape oner it then take it off just before racing, many a drift competetior do it
Good way to get banned from any motor sport if you get caught, Rules are there for a reason, mostly to protect you and any other competitors, Scrutineers are "Anal" for your safety, If they let things go like that and something happens - It makes it harder to get permits for the venue etc again
Leon wrote:Ignoring at least one post in here ...
I'd suggest the easy option, fine metal mesh.
OR, just don't have your bonnet vents facing rearward
RomanV wrote:Adoom wrote:Can someone explain to me this baffling? and how can I baffle it without defeating the purpose of the vent?
Are you baffled as to how to go about this?
Well the idea is to obviously stop oil/coolant/etc obscuring your vision if something sprays out of the engine bay.
So just a simple S bend type setup in the path of flow should do it?
Something that will stop a spray of fluids but still let air through...
Adoom wrote:How will mesh stop the exit of fluids?
Well I could have upwards facing vents but its the same as rearwards.... If it faces forwards im going to get air coming in, not heat going out.
KinLoud wrote:I've seen a couple of solutions to this problem...
- vents pointed towards the side of the bonnet so any fluids would end up down the side of the car (hopefully)
- can't remember number 2 solution ... will make it up later
For your turbo vent problem... is the problem...
- hot air?
- radiant heat?
Is stuff...
- melting
- breaking
- power loss?
-In a rwd starlet??
-Whats getting hot? (apart from the turbo)
-Insulate turbo as you really want to keep the heat in the turbo = turbo will be more efficient (holistic interpretation of efficiency)
-more heat shielding than you already have, to stop stuff melting if that is your problem
Make an air duct that points directly at the turbo to cool it.
Ken
Auck
021 408 863
