good discussion in this thread.
how far or close should the i/c be to the radiator ideally?
mines about 10mm lol (car aint running tho)
darkwolf wrote:I don't think it would make much difference. I think the problem that has occured here is that the turbo has created more heat. So the heat exchange system is required to provide more support. Because air is effectively bypassing the radiator and entering the engine bay Adoom is suffering from higher temps.
darkwolf wrote:As long as the air flowing past the radiator is enough to keep your radiator cool then there shouldn't be a problem. As the air going past your radiator after the IC will generally be heated anyway.
~SlideWays~ wrote:darkwolf wrote:I don't think it would make much difference. I think the problem that has occured here is that the turbo has created more heat. So the heat exchange system is required to provide more support. Because air is effectively bypassing the radiator and entering the engine bay Adoom is suffering from higher temps.
The radiator is going to be waaaaaaay hotter than the intercooler.
~SlideWays~ wrote:More like the intercooler is blocking air flow to the radiator plus the position of the radiator means that the air is not flowing through, instead it is probably flowing around it.
darkwolf wrote:~SlideWays~ wrote:darkwolf wrote:I don't think it would make much difference. I think the problem that has occured here is that the turbo has created more heat. So the heat exchange system is required to provide more support. Because air is effectively bypassing the radiator and entering the engine bay Adoom is suffering from higher temps.
Fair enough. So having it down lower actually advantages the IC so it doesn't soak as much heat as if it was up where the radiator (theoretically - at least to me) would be hotter. Sweet just something I thought of that I'd ask.
Adoom wrote:Oooooh ohh oohhh I can use my new plasma cutter to cut the alloy sheild thingies!!!
Just an observation, wouldn't it be better to have the IC mounted higher on the radiator as then it's not heating the end of the radiator closest to the outlet?
Also, what would be the difficulty in while building the aluminium shields putting water jets in there to cool the radiator/IC if it was required. I don't believe in overkill so it seems like a good idea to me.
Simon85MR220v wrote:You could also cut all the plastic bits out of those two fans you've got mounted on the front of the radiator, leaving just the main supports for the fan motors as its quite a bit of surface area. Did that on my brothers rally Starlet and it certainly helped with the cooling.
Users browsing this forum: Bing [Bot] and 20 guests
