With a GA70 the base torque will drop.
strx7 wrote:Py7h0n wrote:2.5" should still be enough for the power you are making - Going any bigger will drop your low end torque.
How about provide dyno sheets to prove that theory....
I've seen dyno sheets that prove otherwise. Think it was on a 7MGTE MA70 supra. a guy dyno'd with a 2 1/2 inch, then with a 3 inch, same boost levels, no other mods. Picked up a couple of HP down low and 10-20HP in some areas. The normally aspirated exhaust laws go out the window as soon as you put a turbo into the equation
