Backpressure vs Turbo Lag
Postby mjrstar » Sat Nov 08, 2008 6:14 pm
cat007 wrote:
escortman wrote:yeh without tvis if its like a 4age turbo will have crap down low
well the 1G is just like a 6 cylinder 4age :P
I'll try and source all the tvis parts today and put it on.
I guess I'll just have to have a play with when to turn it off, then set one of the aux outputs to turn it off at a certain rpm, like 4,200 etc...
pipe diameter i would suggest that is ID but if it's steam tube and not covered you should still see the size stampings on the bends.
i run don't run TVIS on mine.. looks like too much of a hassle, plus the manifold im running doesn't have any of that junk on it...
like a 4age with head layout. but... the 1g actually has the same bore-stroke as a 4k (75mmx75mm)
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby escortman » Sat Nov 08, 2008 7:18 pm
cat007 wrote:I would measure mine - but that'd only show the outer diameter and I'm not taking my manifold off - still sorting the GTT 'dina clutch lol
o was that what u were doing down at suprachics place saw ur car there this arvo
4x4 toyota blizzard offroader
escortman
Postby cat007 » Sat Nov 08, 2008 11:19 pm
Sure was - and will be tomorrow too :)
Although I'm almost done - YAY
Postby cat007 » Sat Nov 08, 2008 11:21 pm
I'll have a look tomorrow. Yeah it is steam pipe - so will check :)
I should be able to get TVIS working tomorrow - I think I've got the actuator etc - if not I'm sure I'll be able to sort something out :)
Users browsing this forum: Bing [Bot] and 19 guests
