OK so I hooked it up - set it to be on below 4200rpm and did some before and after trial runs. Here's the results.
The ECU logs 10 times every second - so the "readings" are every time the ECU logs data (i.e. 10 times a second)
Without TVIS
Reading: 205 = 2003rpm @ 0.43PSI
Reading: 479 = 4225rpm @ 7.46PSI
With TVIS
Reading: 161 = 2098rpm @ 0.43PSI
Reading: 381 = 4234rpm @ 7.83PSI
So - I managed to gain 0.4PSI from just having TVIS on.
It may not sound like much - but bare in mind, both tests were done with the car at the same temp and on the same stretch of road (up a hill of course). And if you work out, the difference without TVIS took 274 readings (27.4 seconds) to get from basically 2000rpm to 4200rpm but with TVIS it only took 220 readings (22 seconds).
Thought someone on here might find all this interesting
