Oil Feed line to Turbo?
Postby gepsk8 » Mon Nov 10, 2008 5:49 pm
where the best place to get them? hydulic shop?
where do i get the fittings from? (banjo) for clean, tidy install
where do i run it on top mount 4agte, between 2 n 3 or by cas and over the turbo
note heads will be headwrapped
thanks heaps
O272754663
gepsk8
Postby evil_si » Mon Nov 10, 2008 6:00 pm
hydraulink is always good,
use a steel T piece not a brass one as they fatigue over time, run the oil pressure sender off the side of the T and the oil feed to turbo straight out,
keep it as far away from the manifold as possible, this prevents the oil residue baking or carboning on the inside of the supply line on shut down
evil_si
Postby escortman » Mon Nov 10, 2008 9:48 pm
or the hoseshop on rosebank are good guys give trade to almost every1 to
4x4 toyota blizzard offroader
escortman
Users browsing this forum: Bing [Bot] and 25 guests
