SC12 Boost
SC12 Boost
Postby z0ton » Sun Nov 16, 2008 8:13 pm
I know this has been covered many times, but I searched through all the threads and couldn't find the answer I needed...
Anyway I've done the abv mod, and I have a 175mm crank pulley but its still sits on 10psi max. The only thing that needs to be done is make the abv vacuum line go back to the manifold right?
Is there anything else that could cause the boost to be limited to 10? Or is it most likely the condition of the supercharger?
Its an ae101 map sensor engine.
z0ton
Postby evil_si » Sun Nov 16, 2008 9:32 pm
cut and blank the line to the abv completely
evil_si
Postby z0ton » Mon Nov 17, 2008 8:44 am
evil_si wrote:cut and blank the line to the abv completely
I think I tried that a while ago as well. From what I remember it still went to 10 but started dropping back to 6-8 at higher revs. I'll try it again tonight and see what happens.
z0ton
Postby Crampy » Mon Nov 17, 2008 10:05 am
I had a Cusco pulley on my MR2. After the ABV mod, it was pumping out 14psi no worries. Stock intercooler and everything. Front mounts will drop it down a bit normally.
I eventually did get rid of the ABV all together, with no lasting problems.
Crampy
Postby z0ton » Mon Nov 17, 2008 5:09 pm
Blocking the vacuum off the abv didn't change the boost much. It made it drop off a bit more at higher revs.
z0ton
Postby bluemaumau » Mon Nov 17, 2008 5:10 pm
faulty boost guage?
Postby evil_si » Mon Nov 17, 2008 5:21 pm
was that with removing the line to the abv completely? or crimping it?
as will said maybe try another guage
evil_si
Postby z0ton » Mon Nov 17, 2008 5:49 pm
evil_si wrote:was that with removing the line to the abv completely? or crimping it?
I just cut took the vacuum off the tee and blocked it with a bolt?
I've had an autometer gauge on it before and it read exactly the same as my auto gauge one :(
z0ton
Postby Allister S » Mon Nov 17, 2008 6:00 pm
Check your not getting belt slip - can be a bit insidious. Suspicous with your boost falling of at higher RPM.
Using a new belt? Still got good belt tension?
Cheers.
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby z0ton » Mon Nov 17, 2008 7:45 pm
Allister S wrote:Check your not getting belt slip - can be a bit insidious. Suspicous with your boost falling of at higher RPM.
Cheers.
Yea it could be, its a new belt and seems pretty tight, also doesn't make any noises under boost. The falling boost at high rpm only happened when I blocked the abv.
I'll retension the belt now and see what happens :)
EDIT: Well the belt definitely isn't slipping!
z0ton
Postby escortman » Mon Nov 17, 2008 9:01 pm
Crampy wrote:I had a Cusco pulley on my MR2. After the ABV mod, it was pumping out 14psi no worries. Stock intercooler and everything. Front mounts will drop it down a bit normally.
remember the problem i had with my supercharger, sounds very similar only conclusion i could come to was the blower was stuffed
4x4 toyota blizzard offroader
escortman
Postby Crampy » Tue Nov 18, 2008 2:39 am
Yeah Matt. I did all the same things I did on my MR2, but you one just wouldn't boost. Some of those little blowers have had a hard life though.
Cough..... turbo.......... cough
Crampy
Postby z0ton » Tue Nov 18, 2008 10:56 am
If only I could afford it :( Being at uni with no money sucks!!!
z0ton
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
