rollaholic wrote:throwing any fault codes? was it being welded with the ECU still in place
Rick wrote:Welding with the ECU in place is fine but I would disconect the negative terminal and even the postive off the battery, I cant find any hard evidence that it causes problems it just seems funny how it was fine before and not now.
PS I have a few ECU's you can try if you want to see if that is causing the problem..
beeker wrote:AE101 4agze ECU's ?
Mine is a: pn 89661-12790
PS You still got that rusty wreck in your paddock ? I need some hatch gas strut ends. I noticed it had some on last time i was there.
Rick wrote:beeker wrote:AE101 4agze ECU's ?
Yeh I got a couple of the AE101 ZE ECU's. That wreck has long gone but that was a notch back anyway, or were you meaning the AE85 I am doing up
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
