Dell'Orto wrote:Keen as a fat kid in a cake shop, will definately try get onto the M&T trackday.
Truenotch wrote:Do it Jimmy! Looking forward to seeing your new car up close.
Safety gear needed is a Helmet, cotton overalls ant a 1kg fire extinguisher with steel bracket mounted into the car. But you may be able to run without the extinguisher since we will have a good number at the marshal points.
TRDGT4 wrote:just got some final things to sort out but should be all go for the 21st
sounds as if there could be a good turn out
1I1 wrote:TRDGT4 wrote:just got some final things to sort out but should be all go for the 21st
Shall have to make sure im down there to veiw. Any predictions on what times you will get to/hope to get to? Sub 1.20's on the cards?
Boost_4_Life wrote:woop woop might have to make a pilgrimage down with the harlet for the feb one
Return to Palmerston North / Central North Island Region
