Stupid AW11 hand brake WOF issues?
Postby ke25sr » Sat Nov 29, 2008 9:38 am
I dont want to spend another $50.00.
Im going to have a nother crack at the brakes today give him 1 klast chance on monday
I spoke to VTNZ who stated:
you are not to pull up the handbrake on a moving vehicle.
If the brake does not meet the efficiancy requirements you are to test it on a hill.
They will do a test on the hand brake alone then i will ask the owner of the garage to pay my bill.
I dont want a dodge wof. But the car holds on baldwin st. C-mon.
ke25sr
Postby NZ_AE86 » Sat Nov 29, 2008 4:38 pm
It is all in the setup, if you don't adjust the handbrake in the correct way then it won't ever work. It is not an AW11 thing as you will get the same problem with any car with the same handbrake setup that has had someone who doesn't know what they are doing install new pads etc.
They have to test the car on a hill if you ask them. I refuse to pull any handbrake up while a car is moving. All my WOF checks are done on a 1in5 hill behind work. People at VTNZ/VINZ/AA or any other WOF ONLY outfit are generally $&#$% though!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby mr30%jr » Sat Nov 29, 2008 5:24 pm
you have to reset the handbrake pump in the caliper.
its showen in the bgb but its all about adjusting the handbrake right out and then bleading the brakes with the calipers set on to the disc cause when you change the pads you pump the piston right in the handbrake only works a little bit...
had the same problem this seemed to fix it.
bleed brakes after having bed new pads in with handbrake adjusted right out.
mr30%jr
Postby GDII » Thu Dec 04, 2008 6:12 pm
After adjusting the cables and reseting the calipers it did nothing.
Checked if the 1-2 section was straight when the hand brake was on, it wasn't.
Cables are 10-15mm out so have to get new ones made. I hope this fixes it.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby mr30%jr » Thu Dec 04, 2008 6:37 pm
yea they stretch
mr30%jr
Postby ke25sr » Thu Dec 04, 2008 6:40 pm
i have replaced the cables ab re kitted the calipers replaced fluid surfaced discs and replaced pads.
now it will lock the back in the wet ill go for my 4th recheck tomorrow.
ke25sr
Postby johndoe1025 » Thu Dec 04, 2008 8:17 pm
at least they not bitching at you about how far your handbrake pulls up. VTNZ has failed ssome of our customers cars for being like 5 or 6 clicks? wtf?? lol. local garages do wofs better than VTNZ i reckon. on a side note, soon im going to be qualified in wofs :D so if anyone wants a fair reasonably cheap wof, ill let you know when i can do them :P im not into dodgy wofs though :roll:
johndoe1025
Postby GDII » Thu Dec 04, 2008 11:04 pm
johndoe1025 wrote:at least they not bitching at you about how far your handbrake pulls up. VTNZ has failed ssome of our customers cars for being like 5 or 6 clicks? wtf?? lol. local garages do wofs better than VTNZ i reckon. on a side note, soon im going to be qualified in wofs :D so if anyone wants a fair reasonably cheap wof, ill let you know when i can do them :P im not into dodgy wofs though :roll:
The guy who's doing my WOF says the handbrake comes up too far and hes not that happy.
I've got the same guy as you ke25sr. I have never had any problems with this garge. Just anoyed that I have to keep getting it rechecked.
Hope getting new cables solves my problem. The left cable is not as tight as the right when the handbrake is on and the left wheel isn't locking.
1990 SW20 MR2
GDII
Postby Alex B » Thu Dec 04, 2008 11:16 pm
The note thingy on the ajuster on the SW20's say it should go up 5 clicks.
Postby ke25sr » Fri Dec 05, 2008 8:05 am
He Isnt to bad a guy but pissed me off because he thrashed the car and kept ripping up the handbrake.
he never went to a hill and tested the brake so i made a fuss.
Now the brake is working really good.
Im sure he will pass it.
But he has lost all my future wof's
From now on i will go see HRT at his work. Im sure he will do a fair WOF and i bet he will love driving the coupe.
ke25sr
Postby GDII » Fri Dec 05, 2008 8:37 am
I say he failed me for a good reason, just frustrating.
The car needed fixed so that's what I'm doing.
1990 SW20 MR2
GDII
Postby GDII » Fri Dec 05, 2008 10:25 pm
Two new handbrake cables later and it locks both wheels in the gravel. :D
Should pass the WOF now. Then off to Autocross on Sunday. :lol:
This thread has been very helpful.
1990 SW20 MR2
GDII
Postby Lloyd » Mon Dec 08, 2008 11:18 am
ke25sr wrote:From now on i will go see HRT at his work. Im sure he will do a fair WOF and i bet he will love driving the coupe.
Damn right I will :) Give me a yell next time and I'll sort you out
Postby ke25sr » Mon Dec 08, 2008 11:42 am
Early next year ill get a WOF on Me coupe. But it may need a recert yet.
ke25sr
