What I`m after is little tricks I can do or get done to this machine.
Bigger plans can be made when I got more cash to spend.
Twolitre wrote:First things you should always do when you buy a new car is getting it running 100% mint by replacing spark plugs, fuel filter, check timing etc and then start looking at cold air intake, exhuast, cams blablabla........
Peradx wrote:I`ve just brought a 97 levin bzr and apart from 15" mags and what seems to be a larger pipe than standard going to the muff, it`s stock.
CozmoNz wrote:the reason being the 6 sp needs to go into 4th on the qmile, where the 5sp hits 3rd gear high end at that time. thus losing momentiumand hitting the traps slower.
rallymazda wrote:fit a massive turbo on the front!!!!!!!!!!!!!
i find on the 1/4 i hit the rev limiter in 3rd just before the line, either requiring sitting on the limiter for a split second or changing into 4th just before limiter, i recon the 6spd would be helpful in this situation
oh, so you were the white one on the cruise to arthurs pass for magameet aye?
Users browsing this forum: Bing [Bot] and 20 guests
