supra build update
supra build update
Postby avinesh » Mon Dec 08, 2008 10:46 pm
car made 315 wkw at 15psi on t70 masterpower turbo an then clutch started slipping after thats sorted hoping for high 300s with higher boost, car is getting tuned at torque performance....mods are haltek ecu, 850 cc injectors, intake manifold an throttle body an boost controller.... :)
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby YeMs » Tue Dec 09, 2008 12:33 pm
what intake manifold are you using? how much an were did you get it?
Your local Hybrid Elite tech
YeMs
Postby avinesh » Tue Dec 09, 2008 2:34 pm
YeMs wrote:what intake manifold are you using? how much an were did you get it?
custom made was 1500 dollers with 80mm throttle body...
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby evil_si » Tue Dec 09, 2008 5:41 pm
hey yems, have you seen this one?
my mate was looking at it but we need a bigger inlet to suit a 90mm throttle body
http://www.trademe.co.nz/Browse/Listing ... =190931886
evil_si
Postby avinesh » Thu Dec 11, 2008 4:51 pm
car made 440wkw today at torque performance dyno...... 8O :D
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby strx7 » Thu Dec 11, 2008 5:20 pm
evil_si wrote:hey yems, have you seen this one?
one wonders what duration cams the length of those runners are designed for..........................
Postby BlakeNZ » Fri Dec 12, 2008 1:10 pm
holy cow, avenish. 440rwkw is enough to run a high 10!!! yikes.
BlakeNZ
Postby Lith » Fri Dec 12, 2008 2:14 pm
avinesh wrote:car made 440wkw today at torque performance dyno...... 8O :D
Holy shit I was expecting to hear about 380rwkw, of course assuming you were going for about 20psi. Any more info? How much boost? Dyno plot etc??
Nice work, either way - sticky tyres will get you a 10 for sure! 8O
2007 Mazdaspeed Axela
Lith
Postby Bazda » Fri Dec 12, 2008 2:46 pm
Go the masterpower turbo!
Postby avinesh » Fri Dec 12, 2008 2:53 pm
Holy sh*t I was expecting to hear about 380rwkw, of course assuming you were going for about 20psi. Any more info? How much boost? Dyno plot etc??
boost is at 24psi, wont run high boost though need to know the car first will run low boost for tonight around 330wkw mark.....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Adydas » Fri Dec 12, 2008 5:52 pm
How is this a tech related question? moved...
Adydas
Postby Lith » Fri Dec 12, 2008 6:58 pm
avinesh wrote:boost is at 24psi, wont run high boost though need to know the car first will run low boost for tonight around 330wkw mark.....
Ahh 24psi, that makes a bit more sense hahaha - still very nice power :) Good luck for tonight, be interesting to see how you go! Expect updates tonight!!!
Lith
Postby avinesh » Sat Dec 13, 2008 10:36 am
ran 12.2 at 191km/h not bad for low boost....could have done 11s but gear box was acting up a lil not goin into gears properly..... :(
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Lith » Sat Dec 13, 2008 1:45 pm
Nice work!! Gotta be happy with that :) What tyres were you running? Going by the trap speed not drag ones?
Was the other dude with the same surname as you related to you? I see there a turbo Type-R and by the looks of it, it had a lot of grunt!
Lith
Postby avinesh » Sun Dec 14, 2008 11:10 am
Lith wrote:Nice work!! Gotta be happy with that :) What tyres were you running? Going by the trap speed not drag ones?
was running street ets had 60' of 2.1 to 2.2 which i dont understand didnt really use launch control so bogged down was too scared of breaking something lol first time out with the supra :)
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby audi man » Sun Dec 14, 2008 11:30 am
What rpm were you launching at ? i was there racing the red mk3 supra but not having much fun trying to get down the strip with a open diff that was a lsd to start with but i did manage to do a pb with a 10.5@215kms and win the king of the street class.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby avinesh » Mon Dec 15, 2008 1:38 am
was launching at around 3500-4000rpm....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Py7h0n » Mon Dec 15, 2008 6:48 am
Yeah thats a nanny launch ... I launch mine at 6500-7000
Py7h0n
Postby Lith » Mon Dec 15, 2008 7:26 pm
What tyres are you guys running? There is no way I'd launch at >6000rpm on normal street tyres lol
Lith
Postby Py7h0n » Tue Dec 16, 2008 7:35 am
Micky ET Streets
Py7h0n
