sergei wrote:According to Mr Revhead ALL st185s had the same brakes right through the model run.
So if it is a rumour, that there is a difference before and after facelift,
and that prefacelift 185 have facelift 165 brakes, twin piston callpers with 254mm rotor, and facelift 185 have 265mm single piston calliper, is NOT TRUE.
Any JDM normal bodied (ie not widebody) ST185 had the smaller disks with twin pot calipers, same as facelift st165s, all facelift JDM models, GT-Four A's, homologation models, and ALL export models have the larger disks with the single pot caliper.
Diameter Height Thickness Min. Thickness Center Hole Bolt Holes
Stock ST205
315 58.5 32 30 55 5
Stock WRX
294 57 24 22 58 5
