avinesh wrote:Lith wrote:Py7h0n wrote:Micky ET Streets
Is that what Avinesh was running too?
yea but my 60foot was sh*t.....
avinesh wrote:yea but my 60foot was sh*t.....
Py7h0n wrote:Also you were saying your box is acting up a bit? I run RedLine Lightweight shockproof in my R154. It is werid, blue coloured and really helps with the shifts!
I highly recommend you give it a go!! (BNT stocks it)
avinesh wrote:Py7h0n wrote:Also you were saying your box is acting up a bit? I run RedLine Lightweight shockproof in my R154. It is werid, blue coloured and really helps with the shifts!
im running redline mtl now is that ok??? an lith lol my 60foot was same on street tyres an i ran low 12s on street tyres as well was 2.2
avinesh wrote:Bazda wrote:no you want to use the Shockproof stuff, blue.
heard the shock stuff is not good for trans with syncros
Bazda wrote:avinesh wrote:Bazda wrote:no you want to use the Shockproof stuff, blue.
you heard.
You havent tried.
There are some people with bad experiences with it, but there are ALOT more people with positive experiences with this stuff.
If your having shift problems, try it! it will definatly help with shifting and also protect your gears much better than the normal stuff.
I've been running the heavy shock proof for many many many many drag meetings with no issues at all. And many track days as well.
Only now i'm having issues with a bit of crunching into gears after all this time, but my syncros werent new to start with, they were in the box when I got it so they prob done already 150k+. About time I needed some new ones.
I did strip the box down a little while ago when running this shockproof to check the syncros and they were mint.
cat007 wrote:Py7h0n wrote:Also you were saying your box is acting up a bit? I run RedLine Lightweight shockproof in my R154. It is werid, blue coloured and really helps with the shifts!
I assume this would go fine into a W5X box?
What's it worth?
avinesh wrote:got 4 bottles for around 126 dollers
IH8TEC wrote:it's worth it though
Users browsing this forum: No registered users and 26 guests
