Dell'Orto wrote:Minimum thickness difference is 8mm...thats kind of a misnomer, minimum thickness is actually the scrap thickness of a rotor. IE once it gets that low, turf it.
Cliff - the surface area might be the same, but the calipers are expecting to squeeze on something 32mm thick, but are actually having to bite onto something 24mm thick...I'd just be worried that once your pads are worn, they'll end up pushing the pistons out.
The centre hole needs to be reasonably close, but you ought to be able to make up some sort of 3mm spacer to fix that.
We have discussed the piston falling out problem, we dont really see it as too much of a issue as long as he keeps an eye on pad level (easy enough to carry a spare set in the car, only takes 5 mins to change)
It'll be up to the cert man to give his approval
