LSD Identification
LSD Identification
Postby 85AW20v » Mon Dec 22, 2008 9:26 am
Can anyone identify what make of clutch LSD I've got? The letters from left to right are 2 - Z - K. The symbol is like two forward slashes with a fullstop - //. - and a "1" further to the right. There are four square holes around the case, one with the cutout.
See ya
Simon
85 MR2 20v
85AW20v
Postby gepsk8 » Mon Dec 22, 2008 6:35 pm
does it look like this down middle?
viewtopic.php?t=62215&highlight=lsd
O272754663
gepsk8
Postby AceSniper » Mon Dec 22, 2008 8:50 pm
def the type found in some aw11 box's
And also same outside housing as TRD unit
not sure about that cut out though, but everything else matches up
AceSniper
Postby 85AW20v » Mon Dec 22, 2008 9:11 pm
The hole in the centre is bigger than either of the ones in that thread. Best measurement I could work out using a felt pen that almost slid through was about 15.5mm.
Have had to pull it apart to clean it out after problems with the rest of the box and have found that it is adjustable from 2-way to either 1.5 or 1-way, not sure which, just by relocating the four pinion carrier into a different cutout shape. One shape is even angles both ways like this
\_/ and the other is \_| although not quite 90 degrees.
See ya
Simon
85 MR2 20v
85AW20v
Postby AceSniper » Tue Dec 23, 2008 9:47 pm
my thoughts is TRD
AceSniper
Postby Mr Revhead » Tue Dec 23, 2008 10:09 pm
yeah TRD ones do that, and TRD LSD was a popular option on the AW11s when new
Postby 85AW20v » Tue Dec 23, 2008 11:07 pm
It's got six plates - two sets of three - either side of a four pinion carrier that has the 16mm hole through it. One set of plates has four tags to the outside, the other to the inside. The external tagged plates have radial oil lines in them both sides and the internal tagged plates have spiral oil lines. In the photo's looking down on the diff, you can see the radial lines in the holes beside the bearing. On each side there is also an almost flat washer - I wouldn't call it a cone but it definitely has an angle on it. I think this is what gives the tension/preload to the clutch plates once it's all assembled. The pinion carrier sits between two machined pieces and it is these that have the different cutout shapes in them as explained earlier.
Just found this image on Bill Sherwoods site which shows pretty much how mine looks except I don't see the cone washers in there. http://www.billzilla.org/trdlsd2.jpg
You can see the cutout idea on the Cusco site here. Mine is basically the same as the MZ at the bottom of the page. http://www.cusco.co.jp/en/parts_product ... ypemz.html
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
