turbo 4age computer
turbo 4age computer
Postby h8wrxs » Tue Dec 23, 2008 1:03 pm
ive been searching on here for about half an hour and cant find any answers so here goes
im looking to turbo my ae101 trueno... again... i never seem to go through with it
what sort of computer do i need to run, i dont want to go the extent of a link or microtech etc purely for the price
i only want to run low boost, just after a bit more go...
can you get plug in piggyback ecu's for these (i had a primera that had 1)
if not will a 4agze ecu do it, and will the 4agze ecu plug in or will i need to change the wiring loom?
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby 20v_rollaboy » Tue Dec 23, 2008 1:07 pm
What engine have you got in your Trueno?
20v_rollaboy
Postby h8wrxs » Tue Dec 23, 2008 1:16 pm
yeah that might help lol
umm ive got the 20v silvertop
h8wrxs
Postby Bazda » Tue Dec 23, 2008 1:30 pm
If you go through all the troubles of getting a 4agze ecu, it wont work very well with a 20v turbo setup because of the quad throttle bodies.
Easiest way is a link!
if you can find a 2nd hand link you could score one for under $800 easily.
Postby h8wrxs » Tue Dec 23, 2008 2:50 pm
i know completely off topic, but do ae92 lsd gboxs bolt into and straight up to the 20v in an ae101?
h8wrxs
Postby Bazda » Tue Dec 23, 2008 4:04 pm
winston wrote:i know completely off topic, but do ae92 lsd gboxs bolt into and straight up to the 20v in an ae101?
It will bolt up, but you wont have any drive lol
You will need the ae92 gze clutch and flywheel, you will also need the drive shafts as well.
Postby rollaholic » Tue Dec 23, 2008 4:33 pm
if you want to use a 4agze ecu you would be best buying a complete 4agze from an AE101, including loom etc and converting that to turbo.
its got all the bits n bobs you need for boost, and you could sell the SC stuff and your silvertop setup to offset the cost!
