Anyone running an electric heater setup?
Postby Alex B » Wed Jan 07, 2009 9:34 pm
Are you sure its not just so they dont freeze up on cold days? The MR2 is quite good as this trick with no engine to warm up the lines. :lol:
Postby jondee86 » Wed Jan 07, 2009 11:05 pm
On a frosty morning, the water from the screen washer will actually
freeze on the screen and form a layer of ice under the wipers. Heating
the washer water would be one way of making it possible to clean your
screen and still be able to see thru it !!
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Alex B » Wed Jan 07, 2009 11:43 pm
Good point. But how do you unfreeze the lines from the pump to the washer head quickly? Thats more the issue I have.
Postby Dazed&Confused » Thu Jan 08, 2009 3:10 pm
wouldn't spraying hot water over a frozen windscreen cause it to crack/smash? 8O
Dazed&Confused
Postby RomanV » Thu Jan 08, 2009 3:42 pm
I'm actually starting to wonder how likely that is.
Next time I'm wrecking a car or something, remind me to pour hot water over the windscreen in the morning haha
