4ag/ze Water temp sender thread size.
Postby Rick » Sat Jan 10, 2009 1:46 pm
Does anyone know the thread type/size of the water temp sender for the dash gauge, its the same one as the one on the left hand side of the picture, from a smallport 4ag/ze if it makes a difference.
Postby evil_si » Sat Jan 10, 2009 1:56 pm
both the same from memory,
they are a parallel metric fine thread and use the copper washer to seal
evil_si
Postby Rick » Sat Jan 10, 2009 3:33 pm
evil_si wrote:both the same from memory,
Do you happen to know the size? as I need to order an aftermarket sender to suit my gauge.
Postby Rick » Tue Jan 13, 2009 3:28 pm
The water fitting is M16x1.5 and the oil pressure sender is 1/8" BSP 28
