not_paul_from_waiheke wrote:102kpa is normal because you are above sea level. 100kpa is 0 psi, when it goes below that, the engine is sucking air in, when it goes above that then something is forcing air in to the engine, e.g turbo.
l1ttle_d3vil wrote:finally got round to checking the temp sensor.
what would the ambient water temp be roughly, after the car has been sitting in a warm shed all day? ecu was saying 29º before I started it.
or if the sensor is stuffed, is that going to give the wrong reading at the ecu too? thats the only way to get a specific temp to check the ohmes against. i was getting the temp from the ecu thru pclink, and it was:
29º - 1.82ohmes
42º - 1.05ohmes
62º - 0.70ohmes
i have a printout of what it should be just nothing I can upload - but the ohmes seem near enough for those temps. also, when using the factory sensor should "Standard Bosch NTC" be selected in PCLink? guessing the tuner would've altered it if required, but just double checking.
