89 Corona rr window not working
Postby Dazed&Confused » Wed Jan 14, 2009 11:41 am
The rear window on my daily hack is not working. Has been like this since I bought it and am going to fix it. When the switch is pressed, there is power being drained as far as I can tell due to the dimming of the ignition lights.
Will it be just the motor that has failed or will I need something else (regulator?).
Dazed&Confused
Postby phoenix » Wed Jan 14, 2009 1:23 pm
As a start I would try cleaning up the motor (bush) contacts as well as lube up the moving parts of the mechanism and the window slides. See where that gets you.
phoenix
Postby Dazed&Confused » Wed Jan 14, 2009 5:59 pm
Will try on the weekend. Thanks
Dazed&Confused
