Akane wrote:One of the other common problems is that a sticky relay on the older MR2's, I had it a few times on mine, you turn it off and back to on ignition to cycle thru the contacts, it might come right.
solitaire wrote:might sound stupid but i put an aftermarket steering wheel on which killed mine, i took of the sensor on the steering wheel that the ecu uses to figure out how far the wheel is being turned![]()
soon as i wired the sensor back up it was fine
kim0663 wrote:wow i always thought they would be for the rotating fog lights !
Al wrote:If the light came on every now and again, the contacts can get 'dirty', you can remedy this by turning the ignition key ON and OFF about 25 times without starting the car.
