Wondering how the clutch in the paddleshift MRS works.
Hydraulic?
Pneumatic?
Vacuum?
Electric?
Rubber band?
Just got a big attack of curiousness
Ken
Auck
021 408 863
The transmission control ECU controls the pump assembly and the actuator assembly to engage or disengage the clutch and shift the gears.
The Hydraulic Power Unit assembly generates hydraulic pressure for the shift operating system and the clutch release cylinder.
Stroke Sensors : The gear shift actuator houses three sensors that monitor the shift stroke and select stroke of the shift and select lever shaft assembly, and the clutch stroke.
The sequential manual transmission uses a control by wire type shift lever. The shift position and the movement of the shift lever are detected through the combination of the four switches that are integrated in the shift lever position sensor.
