fivebob wrote:Stuff
Py7h0n wrote:Why not just get an aluminium replacement made up?
Get it made thicker and crossflow to ensure everything is 100/100!
Simon85MR220v wrote: A while ago now, Paul Tulloch, from Wanganui Exhaust Centre, supercharged an SW20 and had overheating problems during events. Traced it back to the waterpump cavitating due to the constant high revs so installed an electric water pump and solved the problem. You might want to give him a call.
Mr Revhead wrote:
cavitation could also be due to wrong radiator cap
matt dunn wrote: I also doubt that what you will have done will fix it,
In fact I believe it will make it worse.
matt dunn wrote: Inlet and outlet need to be diagonally opposite each other,
and the outlet needs to be at the bottom to get the cold water to the engine as heat rises,
fivebob wrote: If it's not a blown Head gasket or a bleeding problem then I wonder about the aerodynamics.
Is all the undertray still intact and a close fit to the radiator?
What about the top cover for the radiator?
Is there any room for air to escape around the side of the radiator?
Why is the number plate mounted in the radiator airstream?
Mr Revhead wrote:yeah too low water pressure.
or worn fins on pump.
Mr Revhead wrote:no undertray? surely they mean custom made aerodynamic undertrays.
not standard undertrays.
Mr Revhead wrote:fivebob has a very good point there. the ducting/trays around a rad can have a huge effect on airflow through the rad.
not only infront of it, but behind it as well. if something is allowing pressure to build up behind the rad then how can air flow through it?
pureadrenalin wrote:There isn’t anything to allow pressure to build up behind the radiator after last night. A grinder saw to that. Bye bye frunk.
mr30%jr wrote:making water flow faster through the rad inst allways better it doesnt have time to cool.
mr30%jr wrote:water is being taken from the botom. wherer its cold.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
