RedMist wrote:Its a twin pass radiator!
matt dunn wrote: Inlet and outlet need to be diagonally opposite each other,
and the outlet needs to be at the bottom to get the cold water
to the engine as heat rises,
Why do they NEED to be diagonally opposite, and outlet NEED to be at
the bottom? Toyota obviously didn’t think so. I’m just doing this to make
sure that the bottom is getting even flow.
fivebob wrote:RedMist wrote:Its a twin pass radiator!
Don't think that's possible. The end tanks are on the side of the radiator not the top/bottom, and there is one inlet/outlet fitting in each end tank. Any baffle in the end tank would cause the collant to only flow through half the radiator
RedMist wrote:So Toyota are relying on core resistance to feed the entire radiator?
jondee86 wrote:A car radiator is sized to dissipate the quantity of heat generated by
the engine at full load. At that time it will (theoretically) have a high
airflow, as the car should be going fastIf it is not e.g. when towing on
an uphill grade, the radiator may overheat. On the other hand, when
cruising around on part throttle, the radiator will have excess capacity,
and the bottom of the radiator may feel cold.
This would be more apparent in a TOE design, where the hot water
would be inclined to stay at the top of the radiator. When pushed hard
(as in a race) the bottom of your radiator should be near enough as hot
as the top. If it is not, then you do have a circulation problem, or the
radiator capacity is simply not sufficient for the engine output. Better
airflow thru the rad should help.
Cheers... jondee86
Exide Extract (albeit that its for AGM batteries) wrote:AGM batteries are designed to be operated within a wide temperature range -15degC and +55degC. The optimum operating temperature is 20degC
Higher temps reduce the lifetime...above 40degC there is a risk of thermal runaway
Battery temperature affects the available capacity
Santa'sBoostinSleigh wrote:now from memory water behaves slightly differently, ie ice is cold, but it floats on top of water (if it didnt we would all be fuxed)
however as you get down deeper in water it gets cold again
pureadrenalin wrote:The bottom of the radiator is stone cold, gradually getting hotter towards the top. The inlet and outlet to the radiator are both at the top, and it seams that the hot water is just running across the top of the radiator.
pureadrenalin wrote:I don't think its the head gasket, but since I am now taking the head off, I will be replacing it.
Battery problems are from having a crap battery, and no altanator belt
matt dunn wrote:I see you did a lap of two with no alt belt.
Having done that myself to finish a race I can tell that you that your
waterpump also looses it's drive
fivebob wrote:matt dunn wrote:I see you did a lap of two with no alt belt.
Not on a 3S, the water pump is driven off the cambelt
