4age RWD waterlines vs. Quads
Postby NOLAW » Wed Feb 04, 2009 9:13 am
ok, i have a 4agte running Blacktop ITBs and im in need of the RWD waterlines, iv attached a pic below of what im lost about, the blue circled bits are the hose's that run to the throttle body (correct me if im wrong) but if im now running quads what do i do about these hose's and do i need some other kind of set up for the quads?
please help as it would be MUCH appreciated :P
NOLAW
Postby Bazda » Wed Feb 04, 2009 10:50 am
The whole water system will be 20v as you have a 20v head.
Search google, many people have done water system conversions for rwd applications
Postby NOLAW » Wed Feb 04, 2009 11:12 am
sorry i should have mentioned, the head is 16V
NOLAW
Postby l1ttle_d3vil » Wed Feb 04, 2009 1:22 pm
they can be removed with no problems on standard 16v setup, so you probably could do the same with the quads. is there even anywhere for them to go on the quads?
Postby QikStarlie » Wed Feb 04, 2009 4:41 pm
yeh just block them off
QikStarlie
Postby gepsk8 » Wed Feb 04, 2009 6:16 pm
run one into the other pipe. or block off at the back of the waterpump if ur not running heater,
O272754663
gepsk8
Postby NOLAW » Wed Feb 04, 2009 6:58 pm
oh so do i not even need waterlines if im not using a heater?
NOLAW
Postby l1ttle_d3vil » Wed Feb 04, 2009 7:32 pm
nah just the pipe which runs beside the block, then into the sender unit on the back of the head. all the little pipes aren't needed. can send you pics of my setup if you want.
