fitting qhuads to 16v 4age?? yes or no
Postby LOWDWN » Tue Feb 03, 2009 10:02 pm
bassicly a simple answer is all thats req
just asking wether a quad throttle setup off a 20v 4age will fit the 16v 4age along with will the ecu run it in a ae92
im pushing my luck i think
cheers guys
sam.
021-0290-7728
LOWDWN
Postby Mr Revhead » Tue Feb 03, 2009 10:21 pm
not as a simple bolt on
could be made to work
but not worth it for stock motor and ecu
Postby rollaholic » Wed Feb 04, 2009 7:19 am
easier and more beneficial to transplant complete 20v imo
Postby FULLOC » Wed Feb 04, 2009 11:01 am
would smallport ecu be able to run it? ie just tuck the map out of the way?
im sure fitment wouldnt be too hard
FULLOC
Postby evil_si » Wed Feb 04, 2009 11:20 am
not a simple bolt on, you will need an adaptor to fit the quads to 16v,
evil_si
Postby rollaholic » Wed Feb 04, 2009 12:26 pm
FULLOC wrote:would smallport ecu be able to run it? ie just tuck the map out of the way?
depends on what you mean by run, it might run but probably worse than with standard intake.
need 20v ecu or aftermarket, the vac created by quads is different to a vanilla intake so getting it to idle properly in particular is a problem.
bit of a search should unearth plenty of info for interested people
Postby QikStarlie » Wed Feb 04, 2009 4:48 pm
need aftermarket ecu to make it work properly. otherwise may as well stick with stock setup
QikStarlie
Postby LOWDWN » Wed Feb 04, 2009 6:57 pm
all fair points thanks guys!
sam.
021-0290-7728
LOWDWN
