FULLOC wrote:reset timing and find out...
HRT wrote:Could whip the rocker cover off and make sure the valves are all sitting up at the same height
rollaholic wrote:tough to do a leakage test with no cam chain
buy a toyota imo
Mr Revhead wrote:how did it skip a few teeth?
pc wrote:Sounds odd... I replaced an SR18 head once and from memory the hydraulic part was only to hold the tension. There is a catch system on the tensioner to stop it completely slacking off, was it broken?
Can you see enough of the tops of the pistons down the sparkplug holes to see if there is any surface damage? Maybe a tiny mirror & an LED on the end of a wire will let you see enough.
