I am pretty sure the vvt pulleys screwed, it makes the tractor ticking alot of the time.
It seems hesitant sometimes on power, and has random flat spots (could be linked to screwed vvt pulley?) The flat spots don't really happen at any set time or revs, just randomly when I will drive I will go to give it a little gas going into a 80/100kph zone and it doesn't seem to smoothly go through the rev range, I feel acceleration drop for half a second and my body shifts forwards then gets pushed back as acceleration returns to what it was.
Also, a huge DONK when ever I engage the clutch if I am not really smooth, or if I let off the gas/put it on roughly. If I have the handbrake on and let out the clutch just so it starts to engage it also makes the huge DONK, it sounds like its the engine knocking around in its mounts, which have all been replaced recently with TGP parts (the old ones were not even that bad)
Front suspension creaks over bumps (common superstrut problem, have some lower k's 2nd hand arms and links to go in, hopefully stop it)
The engine has just done over 200k, I have looked after it pretty well, oil and filter changes each, and one of the S/Ts that was in same car (ae101) had 240k and went alot nicer than the one in my car.
Any help on sorting out the engine power and the DONK much appreciated
