Altezza front sway removal.
Postby barryogen » Sun Feb 08, 2009 2:40 pm
So I got a TRD front sway bar cheap as chips($100 second hand), but I'm having trouble removing the end bolts off the factory one, the rest of the bits are off.
The end bolts are loosened, but they are turning, but they appear from feeling them(can't get my fat head in far enough) that they are coach bolts, as in rounded head...
Anyone got a clue on this?
barryogen
2ZZ Guru in training
Postby Lloyd » Sun Feb 08, 2009 2:49 pm
At a guess, get a hex socket that will fit the middle and undo the nut while holding the centre. If the link arm is like most other Toyotas then you're basically just turning the inside of the ball joint in the arm.
Postby barryogen » Sun Feb 08, 2009 2:56 pm
will head home and have a closer look... you may get a text to borrow a hex :)
barryogen
Postby Lloyd » Sun Feb 08, 2009 2:57 pm
Either that or get a set of vice grips in on the other side of the sway bar to hold the middle bit from turning.
Postby rollaholic » Sun Feb 08, 2009 3:23 pm
you'll find some swaybar links have a squared off flange on the back so you can get a spanner on there too
Postby Crampy » Sun Feb 08, 2009 4:29 pm
I had to soak the bugger with CRC for a day before I could get mine to turn. They get a bit rustewd and gummed up by all the normal road grime and stuff like that.
Crampy
Postby neo » Sun Feb 08, 2009 5:54 pm
If its got a little bit of a sway going on, I'd stop letting the front go to the pub so often :roll:
If it has cheap sway bar links, no opening for an allan?-key at the end.. its hacksaw or rattle gun time :cry:
neo
Postby Lloyd » Sun Feb 08, 2009 6:44 pm
Or vice grips!
Postby barryogen » Sun Feb 08, 2009 8:01 pm
HRT wins the beer, it was indeed an "internal" hex.
Got them off, and back on.
Makes quite a difference, certainly takes the tail happy nature out off it.
Buying a decent tool set now, and probably a matching rear sway bar too.
barryogen
