Leiden wrote:Anyone know if the 3SGTE pistons are forged from factory?
LOL, this should be good for a few arguments
http://forums.toyspeed.org.nz/viewtopic.php?t=25880
fivebob wrote:Leiden wrote:Sweet 9.0:1 with the 3SGTE ST215 pistons in the Beams Block, sounds like a perfect little set-up really!
It would be sweet if it were true, unfortunately for you it is not![]()
3S-GTE cylinder head has approx 47cc combustion chamber and 11cc piston dish (these figures aren't as accurate as they could be because I don't have the right tools at hand to measure them properly)
I believe the BEAMS cylinder head has a 33cc combustion chamber. So ST215 pistons in a BEAMS engine, assuming the same piston to deck clearance and head gasket thickness, would give a CR of approx 11.25:1
Also I don't think the valve angles are the same as a BEAMS head, as the ST215 engine uses the same basic head as the GenIII SW20/ST205, not the BEAMS head as Celica RA45 has stated (maybe he's confused it with the 3S-GE ST215 which is a BEAMS engine.)![]()
As to the conrods, the ST215 rods are lighter (and weaker) than the SW20/ST205 rods, that's probably why the one on tardme is bentSadly that's a common fault in Caldina engines that have had the boost raised, and I certainly wouldn't recommend using a set of pistons from a motor that has had a bent rod
Why don't you do things properly and buy a set of Toda pistons which are made for your engine and will give you the correct compression ratio?
Leiden wrote:Found out the pistons I bought are ST246 Caldina pistons... Does the ST246 use a different revision engine than the ST215?
Isn't the Caldina GTT engine a Yamaha Beams engine?
Celica RA45 wrote:the heads on the beams motors have the valves standing up to get more cam lift as five bob said maybe i was wrong but if you ask him how far away are the cam pulleys from each other ,if he says 25mm.then gen 3 motor .if he says 5mm then they are the same as a beams head in valve angle
