help mechanics of dunedin
Postby shihad » Sat Feb 21, 2009 11:39 pm
my 85 4age trueno is leaking oil from somewhere and im unsure where for some beer of your choice please come and diagnose my problem :lol: .the car is in north dunedin. cheers
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby rwd_mayhem » Sun Feb 22, 2009 11:19 am
degrease the whole thing, run it for a bit and then look where it is coming from, it should be easy to see once its nice and clean.
current: 1975 Valiant Regel
rwd_mayhem
Postby Lloyd » Sun Feb 22, 2009 11:21 am
4AGE is likely to be rocker cover gasket or distributor seal/oring. Clean up around those and see where the leaks coming from. Failing that, front seals if its at that end of the engine, or the rear main if its coming from between the engine and gearbox
Postby shihad » Sun Feb 22, 2009 11:32 am
interesting must be the rocker cover gasket and distributor seal so far but i dont think that explains why its on the alternator as well unless its landing on the belt and throwing the oil on to the alternator lol i will get some degrease 2day.
shihad
Postby Lloyd » Sun Feb 22, 2009 11:34 am
The stuff from Supercheap used to be $2-something a can and was actually pretty good stuff. Assuming they still do it cheap
Postby shihad » Mon Feb 23, 2009 10:54 am
it appears oil coming from the front of the motor just above the sump i cant see where its coming from and out of spark plug number 2 lol
shihad
Postby JT » Mon Feb 23, 2009 5:25 pm
shihad wrote:it appears oil coming from the front of the motor just above the sump i cant see where its coming from and out of spark plug number 2 lol
It's not a big deal coming out the front, just annoying. How long till cambelt needs doing? Have to pull everything off to do seals so just do them when you do cambelt. Oil around spark plugs is probably just run off from not getting all the oil in the filler hole :wink:
JT
Postby shihad » Mon Feb 23, 2009 7:53 pm
some was run off but when you run the motor it bubbles over the number 2 lead.was told motor was rebuilt recently so not 4 another 100km lol now i know why the guy told me to run shit oil haha.i drove down from gisborne oil was fine in hawks bay but could have developed the leak anywhere after that.after arriving in dunedin the next day i noticed a puddle of oil under the car checked oil and there was nothing so im praying that it had enough on the way down.
note after thinking about it some more it would have almost certainly been leaking on the way down and would have leaked the last of the oil when i parked up in dunedin as it was parked on the 4th street hill leaning forward.
shihad
Postby cozmoid » Mon Feb 23, 2009 9:33 pm
bummer bro. Hope it's ok.
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby shihad » Mon Feb 23, 2009 10:40 pm
yea sounds like it has a tick or a knock im not sure maybe i have %&($&ed it.maybe im hearing things
shihad
Postby cozmoid » Mon Feb 23, 2009 11:24 pm
get someone u know to check it out. If not damien at graham page engine reconditioning is a toyota freak and would be able to give u a good idea by looking at it.
Ae70/Te71 Hybrid
cozmoid
Postby shihad » Tue Feb 24, 2009 12:17 am
cheers will do
shihad
Postby shihad » Tue Feb 24, 2009 5:30 pm
car is now at graham page engine reconditioning needs a new cambelt due to the oil all over it.the guy there said it could be the o ring around the oil pump.sigh my wallet will not be happy :oops:
shihad
Postby Bling » Tue Feb 24, 2009 6:22 pm
Look at it this way.... it will be happier than if the belt had slipped :lol:
Postby rolla_fxgt » Tue Feb 24, 2009 9:16 pm
BZG|Bling wrote:Look at it this way.... it will be happier than if the belt had slipped :lol:
There always has to be one optimist doesn't there. I bet you'd still find a positive if an asteroid hit the earth :lol:
But sucks to here dude, hope its fixed soon, and isn't too much of a drain on the ol wallet
rolla_fxgt
Postby Stott69 » Tue Feb 24, 2009 9:41 pm
at lest the boy racer problem would be solved?
Image jzs147 Aristo money pit
Stott69
Postby Lloyd » Tue Feb 24, 2009 9:51 pm
Boyracer problem?
Postby Stott69 » Tue Feb 24, 2009 10:56 pm
the astaroid
Stott69
Postby barryogen » Wed Feb 25, 2009 12:11 pm
man we have bad humour...
barryogen
2ZZ Guru in training
Postby cozmoid » Wed Feb 25, 2009 10:50 pm
shihad wrote:car is now at graham page engine reconditioning needs a new cambelt due to the oil all over it.the guy there said it could be the o ring around the oil pump.sigh my wallet will not be happy :oops:
Hey bro . I was talkin to the mechanics at graham page today. Sounds like you have a pretty sweet little ae85 :) Show us some pics. Im glad you took it to them as well as it sounds like ur car will be sorted nice an sweet. He was sayin the rattle will be easy to fix too :) Rwd for life :)
Ae70/Te71 Hybrid
cozmoid
