Supra twin pot brakes - what diameter pistons?
Postby KinLoud » Thu Mar 05, 2009 4:48 pm
Doing research for brake upgrades.
Wanting to know what diameter the pistons are for Supra twin pot brakes.
Also - what size rear piston
Also - what size brake master cylinder?
Thanks
Ken
Auck
021 408 863
Postby strx7 » Thu Mar 05, 2009 5:25 pm
JZA80? master cylinder is one of those horrible double barrel looking things, well all the ones I have seen are.
Postby 2jayzgte » Thu Mar 05, 2009 7:44 pm
Those 2 pot callipers aren't much to rave about either in fact there rubbish I actually chucked mine away they were that bad.
2jayzgte
Postby KinLoud » Fri Mar 06, 2009 8:08 am
Yeah - much appreciated if I can get the diameters please no matter how much you hate them... ;) !!
Wanting to find a set of twin pots that have 42mm pistons - probably off a bigger/more powerful toyota.
This is to help get brake bias pretty correct before the bias valve makes the finer corrections.
Looking at twinpots as 4pots need way more room. i.e. bigger offset wheels/spacers, which begins to stuff up the cost!
Thanks.
Ken
Auck
021 408 863
Postby strx7 » Fri Mar 06, 2009 1:16 pm
try looking at some Daimante's ken. some of them run a large twin pot caliper.
Postby FLAWLES » Fri Mar 06, 2009 3:32 pm
there a big arse heavy caliper ken
i was going to use them on my race car but opted out due to the weight factor and the share size
i know this doesnt help you with sizes, but again from memory sw20 have some nice twin pots i cant remember, thats what i ended up using before i sold it
i use to have some big fat mo fo soarer calipers but the boys at work must of binned them
if i can fine them you can have them
rgds
jarred
FLAWLES
Postby FLAWLES » Fri Mar 06, 2009 3:35 pm
oh
ring trent at totaly toyota in the naki, see if tourer V jzx100's have the size pistions your after
i know my jzx100 runs massive calipers from factory ( mine is a tourer S/V )
FLAWLES
Postby KinLoud » Sat Mar 07, 2009 7:35 am
Thanks guys - thats given me some good leads to follow.
Ken
